Aqualift
- May 20, 2009
- 145
I have been running a 1965 Merc 500 longshaft on my 14 footer for the past 6 years. It has a 11P merc prop and I experience no ventilation when turning or under WOT. I get 5400 RPMs and 30 MPH. Well, I just rebuilt a 1968 Merc 500 longshaft and installed it on the boat. According to old manuals, it should have a gear ratio of 1.64:1. The same as the 65. Thus, I searched and found a new old stock Merc quicksilver prop in 11P. I got in a some test runs back in March and noticed slower speed, higher RPM's and severe ventilation when turning, and minor ventilation with WOT in a straight line. I checked the gear ratio manually and found that it was 2:1. That explained the above, or so I thought.
I was able to quickly track down a 13P merc prop. (all are hard to find for these particular years) I gave the 13P prop a try and I got back the same performance as my 65. The problem that I'm still experiencing is ventilation when turning. It's not as severe, but is very annoying. I can't figure out why the 68 does it. The motor is at the exact same height and tilt. Antivate plate about an inch below the hull. In fact, I raised the 65 to get more speed and rpms with no ventilation.
The only difference is the gear ratio. All the props are the same with no cupping.
Even my marine mechanic is stumped.
