I've been having an issue with reaching top speed over the last two years. I've posted about it in the past, but never found the solution. The motor seemed to go out of gear ? at about 3/4 speed. A 2-cycle genious of a friend, but not a marine mechanic at all, was trying to assist me. He thought that the rubber bushing inside the prop is wore out and is probably slipping under load. So he took it off, put it in a vice, put a screwdriver through the pin holes, and spun it a bit before breaking the screwdriver (cheap)! He's convinced I need a new prop.
If that's so, what are my options? It is a Michigan pr 132 that looks to be about 10 inches in diameter. Don't know about pitch. I have a 15 ft (some kind of V) fishing boat. I don't need crazy performance, but I would like to get it full throttle without is going nuts on me.
