:facepalm: this motor is new to me it has been sitting for 2 years when i got it I rebuilt the carbs and tried to hit the water it ran fine out of water idle and rev was good. when I took it to the lake I started out slow and then accelerated slowly. when I hit around 2000 rpm the motor started to free rev and would not go anymore like It would if I put it in to nutral but the prop was still spinning. I thought it was coming out of gear due to thottle cable adjustment but I put it in gear manually and held it wile we took off and it did the same thing. I was told that it was a bad prop but I just needed a second opinion. I took the prop off and visually inspected it, the splines are good and the rubber bushing looks decent I just dont know how the prop could cause this. I am new at this and I am out of Ideas. Thank you so much
