phillnjack2
Ensign
- Apr 30, 2011
- 918
I would like to know if a propeller that fits a suzuki 13 tooth spline dt60 75 etc will fit an omc 13 spline.
My engine is a 1995 60hp 3 cylinder, same props to fit mine are from 1973 to atleast 2000,the 85hp 0mc and 140hp omc props fit mine and vice versa.
the prop ive come across is a Suzuki 13x21 stainless prop ,the part no: 58100-94571 Type: VS2100
the guy says it fits the Suzuki models:
DF60/70 1998-2009
DT60/ 70 / 75 / 85 / 90 / 100 / 115 / 140 1986-2000
ive been toldthe hub part that goes into the gearcase is around 3 3/4 inch.
Will this fit my gearbox and spline etc, im 100% ok with the diameter and pitch,
its the hub and spline i need to know about
does anyone know if the splines are the same size ? both are 13 toothe.
phill
DF60/70 1998-2009
phill
