I have a 16ft flat bottom fibreglass over ply dory. It has a console steer and false floor. I am not sure what it weighs to be honest.
What I do know is the the prop that came with the BF20D motor, a 4 blade 9.25 x 10", is not getting the motor near it 5000-6000 rpm range.
I have tested it with 2 people and 1 person with different trim settings on the motor. I can only achieve 5000 rpm WOT. Measured by a Teleflex tacho which runs off the alternator.
The motor feels/sounds like it is lugging also.
I spoke to a Solas prop rep who said I should use a 3 blade prop on my rig. He suggested a 3 blade Amita 3 9.25 x 8".
My thinking was that is a huge step, I guess my next testing will tell. If the motor revs over 6000rpm at WOT I will try a 9" pitch Amita 3.
The rep said the Amita 3 has a large surface area, more than some 3 blade designs.
Does all this sound like I am heading the right direction?
I will post the new results after this weekend.
Thanks in advance.
Thanks in advance.
