Re: 1962 gale prop
The 5.5 hp Johnson and Evinrude props should fit BUT... They were changed around 1956 or so and older ones will almost fit, but they won't go all the way on the shaft because they bang up against the bearing housing. And they were changed again, around 1966, the redisigned ones won't work because the drive pin is in the wrong end.
