I just bought a 96' stratos fish/ski 18ft. with a 96' 150HP Faststrike Johnson. Motor runs great and jumps out of the hole. Haven't tried pulling a skiier yet. It tops out around 50mph with just me on the boat. At WOT I am only getting about 4300 RPM's, which I know is way to low. The prop is a 14.5 x 24 Raker. No jack plate. Are the low RPM's a result of too high pitched prop? What is the recomended prop for this set up? What should max RPM's be for my motor? Is there anything else that could be causing this? Any suggestions will help. Thanks
