Hi, I need to know it is true ? if now my boat have Propeller size 24 pich ss Bravo 3 and I want to change to XR 4 blade ( The front) Bravo 3 I have to select less size 23pich'..... It is Correct? Thanks in advance SEE attachement pictures
When up grading from the standard Bravo 3 to the lab finished bravo 3 XR from Mercury Racing, it is required to select one inch LESS pitch in order to match rpm. The reason is that the XR has a more aggressive cupping of the blades compared to the standard set.
Except to gain 3-5 mph at cruising speeds, as well as more aggressive acceleration.
Expect to gain a little (1-2mph) top speed as well.
