I have a 1996 Larson 260 Carbrio that had the outdrive stolen. I am going to replace it, however I wanted to see if I could upgrade it to a newer Bravo 3 outdrive. The only problem is my 1996 Bravo 3 came with a 2:00/1 gear ratio. My local marina has a good deal on a 2001-02 Bravo 3 outdrive with 2.20/1 gear ratio with 23P SS props.
Question: Based on my current setup would a Bravo 3 with 2.20/1 gear ratio work for my boat. I would assume I would need to get a different prop size, maybe a 26P to offset the gear ratio change. I would try to either trade the 23P or sell it and buy a different prop that would make this setup work.
NOTE: I would go with a 2:00/1 gear ratio as before but the difference in pricing is over a thousand dollars.
I appreciate any help or input. Called Larson and they where no help.
