Another weekend out on the water, another issue with my Larson. I have what I think to be a propeller issue however I really dont have much experience with this size boat and engine so I thought I would take the question to the message board for advice. Please see below for the relevant information.
Thanks, Brian
1) Performance issue you are trying to correct.
Low Wide open throttle. Low speed.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
3-blade Stainless Steel
3) Current prop diameter and pitch (required).
14.25"x22"
4) Wide open throttle RPM and speed with an average load (very helpful)
Last weekend 1900RPM/10 ? 15 mph with extra load of approx1540 lbs (including fuel). Using premium grade 91 octane fuel which was fresh that day. Also cleared out the water / fuel separator that morning.
Recalling this from memory but with less weight approx: 900lbs. I was running about 2500 RPM and 25MPH
5) Engine/drive make, model, year, and HP
Mercruiser 5.7L/Alpha One Gen 2, not sure year, 250hp? Engine compression tested last year and had high compression, Rebuilt carb
6) Boat make model, year, length and weight
Larson 220 Escapade, 1995, 23ft, 3430 lbs / Rated for 2300 lbs (gear, persons, fuel)
Thanks, Brian
14.25"x22"
