Anyone try Using JB Weld to "fill" a ding
gdeangel
I churned the bottom a couple of times this weekend - stay away from West Branch State Park / Kirwan Lake - and my prop edge got a little filed here and there but there is one genuine ding where the steel sheared a little and pulled back from the edge of the prop blade. I bent it back with a hammer and some pliers but it's still got some roughness. I was thinking of filling the gouge with some JB Weld and then file down following the contour of the original blade as best I can. Is there any disadvantage to do that vs. just file down the ding right off to the point where the crack / crease ends? I am looking at a crease that is about 2-3 mm long.
Thanks.
scott8058
Re: Anyone try Using JB Weld to "fill" a ding
Have you looked into the cost of having it repaired professionally? I would worry about a blade being bent even if you fix the crease and it running bad. I drug my prop up the ramp once and it was only $30 to get fixed.
gdeangel
What's a good prop shop to use in the Cleveland area?
scott8058
That i don't know i just called my local marina and they pointed me in the right direction......good luck!
jondavies
Google prop repair and you will find several places that will take care of it via mail. I was pretty pleased with Prop MD.
