Hello I have a 1993 25hp Yamaha pull start. The motor is stock without any modifications.
Currently it has a 10x10 1/4" prop. I am making a boat and its loaded weight should be around 650 pounds. (including motor and one occupant)
The boat is a custom fiberglass composite boat (Light weight) the Hull has a rather smooth bottom.
I would like to pull this boat at around 38 possibly 40 mph max speed. However the ultimate goal is not to go at the fastest speed but rather to have the most efficient traveling cruise speed with reasonable fuel consumption.
I understand the max speed for this motor was probably around 28-30 mph but this is a rather light boat and should be able to get faster cruise speed.
Your thoughts are greatly appreciated.
