Hello all,
I am trying to figure out a prop to help optimize my boats performance. I am running a 1992 Concept CC 17'6" with a 1.6l (115hp) 1985 OMC seadrive powerhead on a johnson mid and lower. My current numbers are 6000-6200 rpm at 44mph at optimum trim angle (about 3-4 seconds) with a lighter load and 5400rpm 41mph with maximum load for boat. The service manual for the PH states optimum WoT range is 4500-5500rpm. I have been told that each "step" in pitch will probably lower my rpm by 300-400rpm. I am currently running a stiletto advantage I 13 1/4" X 17 pitch. I plan on keepin the 17 pitch for heavy load days.
For lighter load days, I have been looking into the raker 13.5 X 20 pitch prop. This prop boast high efficiency and top speed with the ability to have the boat ride with the bow a little higher. Does this sound like a good matchup? How much do y'all anticipate the rake, diameter, and pitch change to effect speed and performance and rpms. Also would changing to this prop help improve fuel efficiency? Also, how would this prop perform for low-med. speed trolling?
Thanks for your time and expertise
Scott
Scott
