Re: Prop '66 Merc 50 hp
Not quite clear on your reply. What is the standard diameter? "9" pitch is about maximum it will pull?" Sounds like going for speed, mph, rather than the RPM needed with heavy work load? I prefer the upper end of the RPM range.
Thanks again, I do appreciate your replys.---Jim
