Hi there,
Looking for a new prop for more speed. Right now loaded when I run at 3/4 throttle I get 10 mph(GPS) at 5400 rpm. I can open it up and hit 6200 rpm but I wasn't comfortable reving it that high and letting it run see how fast it would go. With just me and a six year old I get 16 mph at 5400, 3/4 throttle. I am looking to go to an 11 or 12, but I'm afraid the 12 won't allow me to get to 5500 rpm at full throttle. Was going to stick with an aluminum 3 blade as I'm not sure stainless and 4 blade wouldn't just add too much complication to the equation. Any advice on the 12? The required info is below:
1)Performance issue you are trying to correct. - More speed (hoping for about 20 mph, maybe not possible?)
2) Current prop manufacturer, model, aluminum or stainless as a minimum. - Mercury, 87818A10(Black Max I think), aluminum
3) Current prop diameter and pitch (required). - 12 1/4 X 9
4) Wide open throttle RPM and speed with an average load (very helpful) - WOT rpm range is 5000-5500 but I can rev to 6200 rpm at full throttle. Speed with an average load is 10 mph at 5400 rpm
5) Engine/drive make, model, year, and HP - 2006 Mercury outboard, 50 HP, 2 stroke, 1.83:1, not a Bigfoot
6) Boat make model, year, length and weight - 2006 Sun Tracker Party Barge 18, 19' around 2700 lbs
Thanks,
Mark in MN
Thanks,
Mark in MN
