I may want to try the benefits from thoses avantages with a 4 blades prop. Considering I am happy with the 9 X 10 3 blades, should I stick with those numbers in choosing a 4 blades prop ? or is this a totaly new calculation ? TxThe motor probably came with a 9 1/2 X 10 but your prop size would depend on the application.
especially if a heavy boat or a normal large load.4 blades can be helpfull with a heavy boat, for hole shot, and staying on plane.Also may handle better around the dock.It may reduce top speed a little.
