I replaced my outdrive with a new SEI drive and changed gear ratio in anticipation of a repower in (hopefully) near future.
1. 2000 Regal 2500 LSR
2. 25' LOA, 8'6" beam, 4200 dry (not sure if that is accurate) max HP 380(?)
3. 2-10 people, 30-70 gal of fuel
4. normal use is recreational, cruising and water sports
5. deep V, 24 degrees dead rise
6. engine - 2000 Merc 5.0 EFI Alpha I Gen II
7. HP - 240, new outdrive 1.47 (replaced 1.62)
8. max RPM 4800
9. N/A
10. N/A
11. Trim tabs
12. Mercury Enertia 18p, Quicksilver Black Diamond alum 16 x 16
13. WOT RPM Enertia 4100 rpm, 41.4 mph (GPS) Black Diamond 4600 39.8mph
14. sea level
15. tuned, good compression
16. New gear ratio
17. no damage to either prop
18. I'm trying to reach optimum WOT rpm. Prior to changing outdrives I was able to reach 4600 with the 18p Enertia. I would also like to improve holeshot.
19. testing today with 1 person and 1/4 tank, little wind and very little current:
18P Enertia:
3000 27.7
3400 33.0
4100 41.4 (WOT)
16P QS Black Diamond:
3000 25
3400 29.5
4600 39.8
I will be verifying the accuracy of my tachometer tomorrow (but I feel its accurate). Any advice would be appreciated.
Mike
8. max RPM 4800
9. N/A
10. N/A
11. Trim tabs
14. sea level
16. New gear ratio
18P Enertia:
3000 27.7
3400 33.0
4100 41.4 (WOT)
3000 25
3400 29.5
4600 39.8
Mike
