ctf58
- Aug 31, 2009
- 33
Hello fellas,
Got a new to me boat. 1998 BassCat Sabre with a 150 Merc EFI.
It has a 4 blade 24 pitch Trophy SS prop, CMC Manual Jackplate 6" setback and a StingRay III hydrofoil.
The guy I got it from knew nothing about boating at all. Lucky for me he also never drove the boat, he had a friend drive. Secondly he only took it out a couple of times in the past 5 years and the boat only has 75 hours on it. He put the foil on it because he heard they helped with fuel consumption.
Anyway, When I test drove it the water was very rough but the boat did great. Yesterday I got it out for the first time on a good day of water. Boat is fast.
But, up in plane I think I heard the prop ventilating under the foil. I do not need any more speed and plan on taking the foil off to see what that changes.
Where do I start on the height of the jackplate? I've read several post and my head is swimming.
I can really hear it ventilating in sweeping turns and can see alot of spray coming up in front of the foil on the passenger side of the motor. Roostertail is none existent because of the foil.
I think the prop is to high and my RPM's are 5900 WOT at 65 MPH.
Questions are:
1. What should WOT be on a 1998 Merc 150 EFI?
2. Where to start on the jackplate height or how much should I start lowering it 1"-2" ?
3. Hydrofoil on or off until I get smart tabs? When I get the money Smart Tabs will be ordered probably next year.
4. What have I got myself into?
P.S. 5900 WOT at 65 MPH was a full tank of gas (32gal) 3 batteries and 2 people.
Thanks in advance, you have helped a lot in the past!
Questions are:
