Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
See more
See less
Trying to remove prop from volvo penta 280
  • Trying to remove prop from volvo penta 280
    Please help.............no experience here.
    I have removed the locking screw with an allen wrench and the threaded cone. Under the cone was a large spanner type washer which lifted out. The next thing as is appears is the prop itself. Do I need some sort of puller to remove the prop from the prop shaft or should the prop simply pull off? It seems pretty tight and looks as though it may call fall a puller of some kind, but I'm not sure. Thanks for any suggestions, George Santee, CA
    Re: Trying to remove prop from volvo penta 280
    Have a look at the manual for the 280 it might point you in the right direction. http://www.4shared.com/file/48536730...ve_manual.html
    1977 Sea Ray SRV 240 Sundancer
    • #3
      Thanks dgarner, but the link you sent me came up as an invalid link when I tried it. Could you please check to see if you typed it correctly? Thanks George
      • #4
        I copied the wrong link, my bad. The links are right here from this forum. Try this link http://www.4shared.com/get/R-C91eXm/...ve_manual.html And here is where you can find more manuals on the Volvo Penta http://forums.iboats.com/showthread....21#post2360521
        • #5
          Thanks got the link and was able to access manual. Still no info on actually removing my prop after locking screw and cone are removed. The prop is not sliding off the prop shaft spline. Does anyone know if I need a special puller? Thanks, George
          • #6
            Sounds like you've got all the parts removed and the prop should theoretically pull off. You might try a little heat, but be careful to not heat it up too much. Also, you can try gently tapping the base of one of the blades to see if it will budge. Once you get it off, before you put it back on, be sure and apply some grease to the prop shaft.
            • #7
              Thanks am_dew will give that a try and will definitely put some good quality grease on the shaft once the prop comes off. All help greatly appreciated George Santee
              • #8
                Thats correct, it should just slide off.
                You can CAREFULLY try to pry between the round zinc anode and prop's hub with a WIDE screwdriver or prybar to see if it pop's loose. If the tool starts to dig into the metal, stop. The prop is likely seized on and you can try putting the drive up and soaking the spline area in penetrating oil overnight and try again. Then a puller and/or heat...then you might end up having to cut the prop off if no luck.
                2000 maxum 1900SC
                Converted to volvo AQ131/275
                1981 Bayliner Explorer 2270
                Volvo AQ120/270
                • #9
                  That is the same problem I have I removed the center locking screw but I can't get the cone to budge. Any suggestions? This is my first attempt to replace the zinc in 10 years I've had my boat.
                  • #10
                    Put a piece of wood (2x4) between the propeller(blade) and the drive. Use a long screw driver or a metal rod and stick it through the hole in the propeller cone. Un-twist (counter-clockwise), but be careful as not to damage a blade.
                    But if you never removed the prop in over ten years, I fear you'll have much more trouble actually getting the prop off, compared to just the cone.
