Re: 4 Blade SS Props: Solas Rubex vs Solas HR Titan
the Rubex uses a flow torq hub. the Titan is a solid hub. hole shot is going to depend on the pitch and your setup. 4 blades usually will give you better holeshots, but may cost you a little top end.
