pecheux
- Jun 9, 2006
- 1,200
Good day, This 15 hp Force seems to have a 9diam X 8 pitch prop. I get good hole shot and the 14 footer planes with 2 people onboard + fishing gear. I also have a Johnson 9.9 and I get the same top speed with either motor when I am alone in the boat, so I wonder if there would be an overhall advantage to install a 9 pitch prop on the Force hoping to increase top speed but also not loosing planning capacity. On Iboat the only prop that has a 9" diameter is a 7" pitch or 9 X 9, any larger diameter size wont fit. I would appriciate comments. Thank you.
