Re: Anyone using Piranha or other composite props on I/O???
I've been using a piranha for a year now, including a runnin with a shole
on my 83 198c Chapparral, and it's a heavy boat, with a 3.8 OMC stringer 800. I switch back and forth from my 14.5x16 and 14x19 pitch blades. The 19 gives me more speed, but slow out of the hole. I have no problem skiing with the 16, but loose about 5mph top end. After hitting the shole, I lost my skeg, but except for a bit of shaving with a utility knife, (that's right), the prop was basically undamaged, and caused no problems at all when still using it. <br /><br />Now with that said, I've been having my doubts lately as to whether an aluminum would give be better performance (since reading how bad composites are supposed to be in here
, so I've ordered an aluminum 4 blade, and will post the difference results when I've tried it. I hope you guys are right, and I didn't waste my $200 bucks!
