Welcome to Iboats,
Cowbyupnow, you probably need just a prop maximization, go for a wot spin you alone with engine well trimmed on flat, calm no wind water conditions and check achieved max rpm. Compare them to your factory stated min.max wot rpm so to know if inside/outside the ideal safe range. Check how far away you are from them.
One issue is pitching with you alone, other with mate and added weight, for the latter will need to drop more pitch than with you alone to rev up that engine back to ideal/safe range. Must install an induction tach for the wot test. Anyway, what's the max transom rated HP engine for that boat size ?
Some boaters states you gain/lose 150-200 rpm per pitch change, others states 200-300 or even up to 400, don't have a clue for that.
Happy Boating
