Re: evinrude mate prop
This may sound a little crazy for a 2 hp but you could get a tiny tach to check your rpm.
This would get your rpm and give an idea what change if any is necessary. About $50 and easy to install. This is an induction tach with a wire you carefully wrap around the plug wire.Be sure to check all info before ordering.
If its a regular canoe you could use the bow seat and make the boat go stern first.Stern seat forward. You can't go to far forward with the motor it would handle strangely.Using the bow seat as the stern position the motor just behind the seat and you on the bottom forward as far as possible reaching back to steer.If the motor was set up to stay straight you could steer with a paddle used carefully.The idea is to get the boat as level as possible.If a true canoe shape speed will be limited but about 6mph should be really easy to get to.I believe the 2 came with a 7 1/4" X 4 1/2" prop and it appears no optional.I think it is likely any boat would be a max load for a 2
and highly unlikely any boat would be too light a load. The motor is rated at 4,500 rpm.
I think it would rev freely to about 5,000 But highly unlikely it could except under very specific
setup.
