Re: 9'6" inflatable too slow with Yamaha 15 hp
A 9'6" inflatable has a number of things going on.Usually not a particularly efficient hull shape,not much area to help plane a load,The motor may be too low in the water, if inflation is not right and a less than ridged keel the hull shape will distort from the weight and motor thrust.We need more detail.What is" loaded heavy"?
What prop is on it now?Numbers are usually on the barrel or under the prop nut.
What year motor and 2 stroke or 4 stroke?
You really need a tach to tell if its propped right with a light load.A Tinytach is about $47 and easy to install.A gps for speed would be very helpful as well.You shouldn't make a prop change without a tach.
