I have a Suzuki DT50 that has a bad lower end, the pinion is a 11 tooth and the drive gears are 23 tooth (shot).
I have a gear set from a DT 60, the pinion is a 12 tooth and the drive gears are 24 tooth. I am planning to use this set in the DT50 case with the same prop.
Question: Will I notice the difference out of the hole ? I would like to be able to pull tubes/boards with this set up
