I have a 22' pontoon boat with a mercury 90 hp 4 stroke EFI. Currently I am running the stock 13 pitch propellor and can only run about 1/2 to 3/4 throttle running 5500 to 5700 rpm at 20 mph. If I go WOT the rpms shoot up to the high 6000's. Does anyone have any idea's what I should be running for a pitch? 16p or 17p? I heard that every pitch knocks 250 rpm's off. Supposedly that is the stock prop for that boat with 22" pontoons. The pontoon was upgraded with 27" toons supposedly that makes a huge difference on what pitch prop i run. I just do not want to keep buying props until I find the right one. Hopefully someone has run into this and can help! thanks so much!
