PAboater1963
- Jun 13, 2010
- 3
Hi Everyone
I'm new to the iboats forums with a question. My 1986 Yamaha 115hp is leaking oil near the prop. I started the engine today from it's winter rest and noticed a fair amount of smoke, thinking it was from the fogging in the engine. I ran it using a water clamp on the inlet and did not notice any oil leaking after shutting it down. I changed the lower unit's oil last fall and no oil was leaking near the filler screw or the lower unit larger screw. I put the engine in the up/trailer position for the day AND when I lowered it this evening, oil with some water started to drain from the prop. I was wondering if this might be a prop seal going bad or maybe an over service of lower gear oil ?? I bought the boat and engine last year so I don't have a good history of the engine. Any thoughts on this I would Greatly appreciate
Thanks
Thanks
