longshanks
- Jun 12, 2006
- 188
Hi guys
I recently acquired a '03 Mercury 90 2-stroke motor for my boat, a 15' aluminum skiff. The whole rig weighs about 1400lbs loaded, with no passengers. I have tested the rig loaded with 4 adult passengers, as well as by myself, and surprisingly there seems to be no variation in what RPMs it will spin. It tops out around 5000 RPM, around 40-41mph (works out to about 9% slip).
The motor came with a jack plate and it is set as high as it will go before spinning out. No problems with water pressure, but my boat bottom is quite flat and it has a small tunnel in it, which I suspect is causing some turbulence. Bottom line is that I feel the prop is working really well where it is right now, but it only will go to 5000-5100 max.
I am using a brand new Faria 7K tach, and the propeller is a mercury laser II 22 pitch. Although this motor is recommended to spin 5000-5500 I think it would be better for it over the long run to spin closer to 5500. I intend to use it for cruising/fishing, with some water skiing and tubing. I'd like it to be responsive, but I don't want it to kill my present fuel economy.
Does it make sense to stick with the Laser II? This prop seems to perform very well but it wouldn't hurt my feelings to go with something lighter that wouldn't give so much clutch dog rattle. The only issue is that my local shops here in the boonies have nothing in stock, so no matter what I get, I buy, and can't exchange or return. I'd like to get it right first time.
Any advice on whether I should go for a 21P or a 20P or??
