Re: Volvo Penta 5.0 FL Prop
1. Year, make and model of boat 1995 Larson SEI 19
2. Length, width and base weight of boat, look for boat decal on back of boat 19 feet, 7.5 beam, weight??? Its night time right now
2a.What is the maximum recommended HP for your boat unknown
3. Number of people and gallons of gas normally on boat 3 to5 people 25 gallons
4. What do you use the boat for cruising, tubing, knee boarding
5. Is it a Deep Vee and if so how many degrees of deadrise bowrider, reg Vee I guess?
6. Year, make. manufacturer and model of motor 1995 Volvo Penta 5.0 FL
7. HP and gear ratio of motor IMPORTANT 190 HP
If you don?t know the ratio, you need to pull the plugs out and put a piece of tape a c ross the prop and the lower unit and then cut it between the prop and the housing and turn the motor until the tape lines up with each other, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
8. Manufacturer?s recommended Wide Open Throttle (WOT) range 4500 RPMs
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches, use a board under the keel and stiking out to the anti ventilation plate for a referene ????
10. Is it a bass boat or does it have a pad bottom no
11. Does it have a hydrafoil, dolefin or trim tabs has a fin, on back of outdrive
12. Make, model, diameter, pitch and whether SS or aluminum prop Alum, 20 pitch 4 blade
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. Make sure you trim the prop up until it starts ventilating and then just trim in until it quits ventilating. If you do not have a tach you can buy a Tiny Tach for $ 50 From GPS, 40 mph 4200 rpm, can trim up and get more rpm, but speed does not increase
14. Are you at sea level or a higher elevation, give us the elevation in feet sea level
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the foregoing could be the reason your prop is not attaining full RPM fresh tune up and heads rebuilt
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop came with boat
17. Does the prop show any damage that you can see no
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations more top speed
19. If you are trying to attain a better cruising speed and fuel savings or trying to attain a faster speed I will want you to take your boat and run it with 1 or 2 people and give me the RPM and speed readings starting at 3,000 RPM in 500 RPM increments all the way to WOT.2 people WOT 40.5 MPH, 5 people WOT, 38-39MPH, 3000 RPM is about 26 mph or so.....
Everyone loves pics...
