jhoncho4x4
- Jun 4, 2009
- 7
I am wanting to use my 10hp Martin 100 for a kicker motor on a aluminum 1969 19' Starcraft Starchief cabin cruiser. Does anybody know if the prop that fits the Martin 100 is the same type that is used on a modern brand of outboard? That way I can order a high thrust prop for that brand and use it on my Martin. My Martin 100 is a 1953 aquamatic with clutch.
I am also open to any suggestions on the proper prop (size/pitch) to use for the kicker.
My boat specs are:
120 hp Mercruiser Inboard Alpha 1
Concave Vee
Center Length- 18' 4"
Gunwale Length- 19' 7"
Beam- 85"
Bow Depth- 44"
Center Depth- 38"
Transom Width- 75"
Transom Height- 39"
Approx Weight- 1,600 LBS
Recomended Capacity- 1,700 LBS
There would normally be no more than 4 persons.
Later today I will post on this thread a picture and specs of the prop that is on the Martin now and the gear ratio of the lower unit.
My boat specs are:
Concave Vee
Beam- 85"
Bow Depth- 44"
Center Depth- 38"
Transom Width- 75"
Transom Height- 39"
