turbodude51
- Aug 2, 2007
- 21
I have a Mercury 500 1964 50 HP short shaft on a Mercury 430 HD Inflatable with steering console etc. Worked on Motor all winter, when you start to push more than half throttle, prop slips, hub seems fine with tests. Prop on now has this number: 48-38094-1, has a 12 on side so I assume it has a 12 pitch. I found a new Mich prop on e-bay number 030286 which I hope will be better. Props are hard to find for this motor as it is eleven spline. When slipping starts you can reduce throttle and it will be okay. Any thoughts? I was in back while wife drove and everything seemed okay but it wasn't! Thanks in advance for any thoughts on this. I did check trans adjustments also.
Rick
Rick
