I have a 2006 Tracker Pro Team 175 with a 2006 25 HP Mercury 4 stroke. The boat is 17'6". Thats the largest motor I can use on a local favorite body of water. I have a 24V 70 lb thrust trolling motor, thus there are 2 trolling motor batteries and a cranking battery in the stern. My prop is 9.75" diameter but I am having a hard time reading the pitch, I belive it is 9.5 though. It has a Mercury model #896892A40. It is aluminum and shows normal signs of use for its age.
I do all I can to keep the weight in the boat at a minimum, and with just me and a light amount of fishing gear I can get the boat up to 23.4 mph on the GPS at about 5600 rpms. I never fill the 21 gallon gas tank more than half full and rarely use the livewell. With another 200 pound guy with limited gear I can still get the boat up to about 19 mph at 5000 or so rpms. If I have a larger passenger with me and/or they bring more gear, the boat really struggles to get over 15 or 16 mph.
I am hoping that a prop change/upgrade might help to get the rpms up around 5600 and roughly 20 mph fully loaded. A friend has the same boat with a 2005 Bigfoot Mercury 25 and an 11" x 10 prop. His boat handles the extra weight better than mine does.
My limited research suggests that changing to a 10" x 8" prop may help. I am willing to spend the $ for a better prop (stainless? 4 blade? etc.) if it will help. Obviously, my boat will never be fast, but 20 mph is much more acceptable than 15 mph if I can find a way to do it.
Thanks in advance for any and all replies/suggestions.
Husky
Husky
