Hi,
I have a 1997 25 Hp Honda on a 14' Twin Vee, center console. I bought the boat a couple years ago and the boat ran fine when I tested it. Since then I installed a CMC PT 35 Tilt bracket and the boat has rarely gotten on plane since then. As I open the throttle, the motor seems to bog down and pick up intermittantly thus causing the boat to not plane. The motor idles very well, starts up right away and never shuts down while running.
I was told that it was plugged up carbs so I had the carbs rebuilt, plugs changed and all fuel lines and vacuum lines replaced. After the service, the boat still bogs down at full throttle. If I pull back the throttle, the boat runs fine.
I am being told that the CMC bracket probably raised the motor so I am hitting the rev limiter as my RPM is too high and I need to increase the pitch on the prop.
The prop I have is a Stainless Steel prop and does not have any marking on it to determine the pitch.
What should I do to get the boat running back up again.
I could use some help and advice to test stuff before I start making changes on recommendations that may or may nor work.
