Hi , new guy with a new to me boat. I have a 28' 1984 Chaparral 278 XLC cruiser. It has a single Mercruiser 260 with an Alpha one drive. The drive was originally a 1.50 ratio I think. I can't be for sure because all of it is painted over but all the info I've found says that is what it was. I'm not sure what prop this boat came with originally either but it had a 16" diameter 13 pitch prop.
Anyway the drive was bad so I replaced it with a 1.84 that I got from a friend that had a smaller diameter ( not sure what diameter) 21 pitch prop. I tried it with the 21 pitch prop and maxxed out at 4000 rpms and 20 mph according to the speedometer. I switched it out for the 16" diameter 13 pitch prop and maxxed out at 4500 rpm's and still 20 mph according to the speedometer.
I'm not sure if I was getting that much slip with smaller diameter prop or if the speedo' is off. I haven't tried it with the gps yet. I know this is a large boat but does only 20mph sound right? Anyone know how fast these were stock? Do I need a diffrent pitch- big diameter prop? Anybody have any ideas?
Thanks,
Eddie
Thanks,
Eddie
