Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Prop hub kit installation
  • Prop hub kit installation
    Just wondering if anybody knows if you need a special press or something in order to install a new hub kit in an existing prop. And if there is particular way in doing it. I spun the hub in my prop over the weekend and want to install a replacement hub myself. Is it tough to do? Any information regarding this procedure would be highly appreciated.
    Thanks,
    tuneball
    Re: Prop hub kit installation
    Just like anything it's simple if you have the right equipment. Now, we're assuming your prop has the old style pressed in rubber hub. It's not a prop that accepts the new style push in type hub kits like a Flo Torq or T-Lok etc.
    If it's the press in old style then you'll need a press. I believe you need about 15 ton pressure, not quite sure. Then you need the inset cone and whatever chemical they use to start it in. You'll also need a way to clean out the remains of the old hub once you press it out. The guys I watched do it used a glass beader.
    And naturally the hub itself. Most manufacturers will only sell hubs to prop shops.
    • #3
      What exactly is an inset cone??? And what does this chemical do, where is it applied?
      • #4
        Sorry to partially hijack your thread here I could use some info too.
        I just ordered a new prop and hub kit for my motor... are there any special tools involved in installing them?
        I didn't think it was going to be that complicated.
        • #5
          The cone is a taperd cone the compresses the rubber on the hub as it goes in. I suspect it also centers the hub. The chemical (I assume) makes the rubber slipery so it goes in easier and then perhaps disapates or turns to glue. I've watched it done but never got into the details, it was easier to let them do it.
          • #6
            If it's the push in style hub, not the pressed in style, then it simply pushes in. With a Flo Torq or similar hub kit I coat the rubber with soap and it slides right in. The old style pressed in hubs are different.
            • #7
              Hope this helps
              http://www.*************/Propeller-Ge...stallation.htm
              2000 SSi 196 Chaparral Sport
              2001 Sea Ray 186
              1993 Glastron SSV190
              Deck Restoratiion
              Swing Away Tongue
              Transom Restoration
              13 X 21 Stiletto SS Prop
              Trailer Crossmember Repair
              • #8
                Thanks for the info. guys, much appreciated, I actually found a guy that does it for $20, I'll bring it to him and watch how he does it, for next time.
                Thanks again
                tuneball
                • #9
                  That's an amazing price. The hub costs more than that. If he needs more work, let me know. I'll send him all the props I need rehubbed.
