hi i just got my motor and started it and it took about 20 seconds for the water to comr out and after that it worked good until i would stop the engine and started it again,the same thing appened.is this normal for these kind of engine or i should change the water pump.if so ,i would like to know where it is located i also think that the prop is to little for the engine.i have a 50 hp evinrude and the prop is way bigger.what is the normal size for the prop.thanks
