1978 VIP 15ft Stick Steer w/ '78 70hp Johnson
Jamis
Can you guys give me an recommendations on size and pitch for a prop? It's a fiberglass tri-hull, front stick steer. I know it has a 13 spline and it had a 13x17 prop that seemed to work pretty good. I tore up the prop something fierce last weekend and now need to replace it. Was this a good setup for this boat?:confused:
steelespike
Re: 1978 VIP 15ft Stick Steer w/ '78 70hp Johnson
Without Max rpm and speed its difficult to know where you are at.Its criticle, to the motors health that it operate within its proper rpm range.You might see if a prop shop can repair it.Then get the figures for us and we can fine tune it.
Jamis
Any cheap way to find out the max RPM's without buying and installing a guage? As the boat is a stick steer, it has no guage cluster. I can find max speed from a hand held GPS, I assume, but I wouldn't even begin to know how to get the rpm's.
mpsyamaha
i have a brand new (used 30mins) Solas stainless steel 13 1/4 x 17 prop that should fit your motor that i am trying to get rid of. Shoot me a PM if you are interested at all.
