krizm200
- Apr 30, 2017
- 67
Hi everyone,
I have been reading through posts on props, and coming up with more questions than answers. I have a 1972 Mercury Thunderbolt 800 80 hp, 4 cylinder outboard on a Mako 15 (total weight about 1200 LB's). My prop is a 3 blade aluminum 13x19 that I replaced last year (same prop size that was originally on the outboard). The highest rpm I get according to my new tach (Faria Euro) is about 4300 at WOT. At 3000 rpm's my speedometer reads about 23 mph (this is a Faria GPS speedo). I have 2 questions:
Should I be getting higher rpms? I keep reading the outboard should get 4800 to 5300 rpms. If I should, would a 13.25x17 prop make more sense?
I usually run the engine at 3000 rpms, Mako is on plane, and the engine is running smoothly. Will this cause damage to the engine? I read a post online that mentioned this could destroy a piston? They wanted WOT for running the engine. I don't understand why running under WOT would cause damage to the outboard.
I will eventually try to pull up a water skier (I need to install the pylon yet). I know I can hit 30 mph, so I assume I should be able to pull up my 13 year old daughter on 2 skiis. I understand 25 mph should do it.
Any help would be appreciated. Still learning the ins and outs since I bought the boat last Spring.
Thanks.
Thanks.
