Problem solved. Discovered the 12vdc Boatstogo air pump wasn't putting out the correct air pressure. Although it's supposed to be capable of producing up to 12 psi (80 kpa) via an adjustable knob, it was only putting out a fraction of that even when adjusted for max output. Received the K-Pump air pressure gauge today and pumped up the boat using a manual K-Pump to the recommended pressures. Also installed a hydrofoil. Boat now gets up on a plane with no problem with zero cavitation/ventilation issues.
