I came across a Stiletto Advantage stainless prop in the correct size for my boat but the hub is a 13 spline Johnson or Evinrude. Can I get a different hub kit and convert it to a 15 spline for my old 75 115hp Merc? Thanks
I see that the stiletto advantage props have the interchangeable hubs so it would be an easy replacement. You'll have to google search where to get one in a 15 tooth spline. Amazon should have them if iboats doesn't. Look at the prop first to make sure it's the same hub system, some older props had a different hub style.
