bhollehday
- Aug 16, 2017
- 77
1) Performance issue you are trying to correct.
Slow to plane, no power out of the hull, doesnt max out RPM with more than 4 people
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
Prop was just lost in the river, but it was a 3 blade aluminum and was told it was an 18pitch
3) Current prop diameter and pitch (required).
Unknown
4) Wide open throttle RPM and speed with an average load (very helpful)
4600-5000 RPM
5) Engine/drive make, model, year, and HP
5.0L Volvo Penta, 2006, 270 HP 1.6 Gear Ratio
6) Boat make model, year, length and weight
2006 Larson Senza 206 ,3150lb dry
I was looking at getting a Stilleto Bay Pro II 18p and found a good one locally for $180 with the hub. Its a 4 blade SS prop though and not sure if I like the idea of SS or really need it. Im afraid if I hit something that I might damage my outdrive compared to using an aluminum prop.
Does anyone have any alternatives for a good starter prop? I would like to be able to pull a single skier out of the water with 6 people in the boat. It previously felt powerless.
Unknown
4600-5000 RPM
