Here are the specs I have:
2000 Maxum 2300 SC weighs approx 4500 Ibs
23' deadrise
Bravo III with 26p stock prop set
7.4l mpi
The drive has be repainted and I can;t read the serial number. It is also not on the top of the motor. Right now I am hitting the rev limiter at 48 mph (gps) with 4 people on board and full tank of fuel. My tach seems to be reading a little high. The info I have read on this forum indicates the rev limiter kicks in at 4680rpm (my tach is close to 5000 rpm). Using the prop calculator it looks like it has a 2.2 gear set - yielding a slip of 8-9%.
Any thoughts on what to do? I don't know if someone swapped the drive on this boat at some point, but it seems to be very under propped.
23' deadrise
7.4l mpi
