I have a Yamaha P 165 8 hp Gear shift works, but prop won;t turn. Reply to ricc@shaw.ca
H hap777 Cadet Joined Oct 23, 2012 Messages 22 Jun 27, 2017 #1 I have a Yamaha P 165 8 hp Gear shift works, but prop won;t turn. Reply to ricc@shaw.ca
MH Hawker Vice Admiral Joined Jul 13, 2011 Messages 5,516 Jun 28, 2017 #2 i can reply right here,,,, the LU may be toast the standard testing is to first drain and look at the LU oil for metal particles, depending on that, then drop the ul and see if the motor will sill turn
