chevy91174
- Oct 6, 2015
- 5
I was given a 1976 Deckette Deck Boat from a friend. Been setting up a couple of years. The problem is the existing prop is badly chewed up and needs replacement. I doubt I would get much useful info by testing WOT operation with it, besides it would probably vibrate pretty bad. The stamping on the prop barrel is illegible, looks like to says "1012" but that doesn't make much sense. Best I can tell measuring, it is a 14" to 14.5" prop, but hard to say as there is a lot of blade material loss. Aluminum 3 blade. I just don't know where to start with a replacement. Anyone have a suggestion for where to start? Props are a little too expensive to have to change too many times, and I really can't think of a way to baseline this combo. Anyone have a similar setup?
Boat: 1976 Deck Boat "Deckette
Motor: 1976 Mercruiser 140 HP Stern Drive
WOT ROM range: 4200 - 4600
Weight: best I can find online says 1800 lbs
Usage: will be for pleasure cruising with 2 - 4 people, and maybe pull a tube on occasion. All around performance/cruising.
I can't seem to find an owners manual available, but I did get a service manual for the engine/stern drive.
