I have had a lot of time on a boat but havent owned one myself. Ran into an issue with the out-drive and had to buy another alpha one gen 2, was lucky and got a refurbished one for 450$. My problem is the prop that came on the boat is in the bottom of a lake since the out-drive completely exploded at only 5knots. Upon inspection it looked like a bearing seized up and started to spin in the lower units case and bound up and popped. Or the seller I got it from whacked something and it was just a matter of time before it would blow since its structural integrity got weak. Before you jump to asking if there was oil in it, Yes there was I changed it right after purchasing it, used quicksilver sae90 in it, and did all the other maintenance needed prior to all this happening.
Anyway I just want to know because for the life of me searching google I can't seem to find what the stock oem size prop that came on the 1995 stingray 556zp. I know you can mess with different pitches to get more hole shot, top speed, cruising etc, but I just want to know what it originally came with so I can have a starting point and order one. Thank you in advance if you can help. It's WOT is 4600 or 4800rpm and its a mercruiser 3.0liter. I can confirm it once I get to where the boat is being stored/worked on. If you need any other information to help me find the answer I'll do my best to reply quickly.
Just for your viewing pleasure and my embarrassment here is a photo of the after math WARNING VERY GRAPHIC lol jk
Thanks for your time
-Jay
-Jay
