Chrisravosa36
- Aug 16, 2015
- 622
Hello, My maiden voyage on my 17ft restored mako didnt go as planned. It was well, the boat and engine did fine but I was planning on seeing some better #'s. I got 27mph @4500 rpm that was W.O.T. The motor is definitely lugging. Im guessing its supposed to be hitting at least 5250 - 5750. Its a 1972 Mako, with a 1988 140 Evinrude/Johnson. It was off a duel application, two 140s on a 24ft Mako. Im guessing the prop, it didn't propose until trimmed to high, so I believe the motor is at the proper level with the bottom of the boat? Any advice. I know with this motor and boat combo I should be hitting atleast 35MPH all day long. I did a compression test on the motor and it reads 120 on All 4 cylinders.
Thanks, Chris
Thanks, Chris
