jackrabbit66
- Sep 26, 2014
- 58
97 Tohatsu 120HP two stroke outboard
I recently removed the lower unit to do some maintenance. I needed to clean out some build up from the speedo tube, replace the impeller / gaskets, and generally check and grease things. This is the first time I've done this since I bought the boat a few years ago. I had taken off the propeller before this however I never bothered to remove the spacer behind the prop. I only discovered it was removable when i looked up the lower unit removal instructions in the manual.
The shop manual indicates I have a thrust hub Type prop assembly (pictured below). I've tried WD-40, I've tried prying it up, I've tapped on in from all sides. I'm concerned that if i apply too much force I'm going to break something. Anyone has a suggestion as to how to remove this?
Thanks!
Thanks!
