I have a 1997 19' BMC bass boat, heavy, but have no idea how many lbs. Mercury Black Max XR4 150hp eng. prop has no name nor # that I can find, it came from a prop shop in Nashville. I was told it was a 13" 24 pi. When taking off, the motor moans & strains for appx. 8 to 10 sec. before it plains off, then maxed out turns right near 5000rpm, just what the manual says it should turn. I have found a 5 blade 24pi High Five prop, for a reasonable $$. Could I expect very much difference in the hole shot or max rpm with this 5 blade compared to the 4 blade? I know there isn't a definite answer, but could I expect a noticeable difference or no difference at all? Thanks, Rick P.
