I have a 2008 Stingray 220DR with the Volvo 5.0 MPI 270 HP SX. The prop on the boat right now is a Turning Point LE-1417, 14-1/4" x 17 aluminum 3-blade.
The prop is pretty chewed up and corroded, and I'm looking to replace it with a stainless prop. I've tried to do my best to research what I need, and I've had friends tell me I should go to a 4 blade 19 pitch.
I've been satisfied with the performance of my boat and am not looking to do anything radical. I don't pull skiers, so hole shot isn't a huge issue. WOT is around 5100rmp putting me around 42mph or so.
Before I just go out and buy an identical SS replacement, can someone give me some input? Should I consider 4 blade and/or a higher pitch prop?
Thank you in advance...
